New engine. Need to switch trans?
Old Jan 27, 2001 | 12:13 PM
pogo's Avatar
pogo
I have a 68 T-bird that I'm looking to put a 351W into. The car has a C6 transmission already in it. If I put this engine in the car would I have to switch out the trans?
Old Jan 27, 2001 | 12:33 PM
rc351w's Avatar
rc351w
First off, what was the tranny mounted to before?
RCC
Old Jan 27, 2001 | 03:49 PM
pogo's Avatar
pogo
The factory 429 8cyl engine
Old Jan 27, 2001 | 04:36 PM
StrangeRanger's Avatar
StrangeRanger
Different bellhousing pattern. Your best bet is to get a small block c-6, which will bolt up to the 351W. The big block C-6 that's in there now is VERY marketable at swap meets, etc. DON'T just scrap it out.
Old Jan 27, 2001 | 10:01 PM
pogo's Avatar
pogo
I wanted to try avoid changeing the transmission right away. It's still in good shape
Old Jan 28, 2001 | 07:24 PM
pogo's Avatar
pogo
What Kind of transmission should I get?
Old Jan 28, 2001 | 09:31 PM
StrangeRanger
A small-block C-6 is your best bet, it would be a direct bolt in. An AOD could be made to fit, but it might not hold up well behind a 351. An E4OD could also be made to fit and would certainly be strong enough, but it requires an electronic controller.
Old Jan 29, 2001 | 10:54 AM
slikness's Avatar
slikness
or...put a big block back in, 351M, 400M, 460?, etc.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Jan 29, 2001 | 08:18 PM
pogo's Avatar
pogo
Would it make much of a differance if I put in a 351W big or small block? The cars weight is about 4000 lbs and I'm not going to be towing anything. A small block C6 should work in either ease right?
Old Jan 29, 2001 | 08:29 PM
billyb's Avatar
billyb
a 351w is a small block engine. i'd stick with the 429.
Old Jan 29, 2001 | 08:48 PM
pogo's Avatar
pogo
The 429 is as expensive to repair then it is to buy another engine not to mention it gets the 8 mpg for stock performance. This car is also driven daily. What kind of trucks come with a 351W?
Old Jan 30, 2001 | 05:36 AM
pogo's Avatar
pogo
Or does anyone recomend any other big block engine?
Old Jan 30, 2001 | 04:56 PM
StrangeRanger
If you don't like the mileage on a 429, you probably won't like the 460 either, but it's your best bet. 460s are plentiful, give a ton of torque and are a direct bolt in. A fresh one should give you better mileage than you've been experiencing. If you can't or won't stick with the big block engines, that leaves you with the 400M or the 351M, which use the same bolt pattern. Problem is, the motor mounts, etc. are probably not going to work and you'll probably need a trick oil pan. If you weight the cost of conversion against the fuel mileage gains, you may be better off just rebuilding the 429.
Old Jan 31, 2001 | 05:23 AM
pogo's Avatar
pogo
I'll start looking into the 460 a little . If a 351 gets about 12.5 mpg is it really worth it to put a computer in it? It only saves about 1 mpg right?
Old Jan 31, 2001 | 04:56 PM
hpguy's Avatar
hpguy
MPG is really a big variable, depending mostly on how close to the carb your foot stays.
I would suggest a 460. No reason, just more displacement
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
