My 79 F100 that I have lent to a friend is acting possessed - I haven't looked at it yet, so all I have to go on is his description of the problem. So with very little info and no truck to look at- I'm making this appeal to all you psychic Ford fans to name that issue! It is a 351M with a older looking cast iron Edelbrok intake and a Holley 4 barrel ( it's a 4160) Two months ago it was coughing and sputtering, wouldn't idle and kept dying. I rebuilt the carb, changed oil, cap, rotor, plug wires, plugs and fuel filter... and it ran fine. I wish now I would have done one thing at a time to see what made the difference. Any way, a day ago it was running fine for my friend, he stopped somewhere and when he came back and started it it was doing the same old trick - won't stay running won't idle. ---I'm thinking either a plugged fuel filter or a sticking float. What does your magic ball say?
When I got my 79 it was very temper mental for the first few months. I still have nightmares. Hard to keep it running, wanted to die, took 10 minutes to start. Ended up replacing the carburetor with an Edelbrock and it fixed it.
Very possible its the fuel filter in your case, any kind of crud in the tank could have come loose and plugged it. Its the first thing I would check before ripping the truck apart.
I know....I thought of posting there later too... I did run a duplicate in the 351 engine forum though! I'm blaming it on too long of a day at work! So the ignition module would make it act like that? Also, I did have the gas tank out a couple of months ago so maybe I stirred up some gunk that plugged up the new filter...
it takes a bit to plug a new filter. You have a single tank I take it with no switch for a second...i had a dual set up with one tank...but it got switched to the 2nd and acted the same way...very weird that it pulled enough to run for a bit at a time.
If ignition it could be anywhere from the harness connections under the hood to the module. Recently had to splice past a connector. It would be good to test electrics when not running...see if you have fire then work way back to coil, module etc if you don't. original modules do not allow much for cooling...place washers between module and inner fender so air can circulate better and heat is not reflected back. Some parts stores can test modules but not sure they can adequately test a tempermental unit.
Basics....fire and fuel...if you have fire when it won't run you know it's fuel and vice-versa.
Does it have EGR? I had problems with a chunk of carbon coming loose in the EGR and it wouldn't close properly. No idle or low speed driveability, had to 2-foot it across town.
When it's running bad, shut it off, pull off the fuel line from the filter (after eliminating the filter as the problem) and blow into the line toward the gas tank. Reattach and crank her up. If she runs good then, you got junk in the line/tank.
What's up with not posting in the 73-79 forum?
Tempermental Ignition Module is my guess
I second the motion. Replace the pickup coil (stator) in the distributor, also.
Use ONLY new MOTORCRAFT parts, the gypo aftermarket modules are made in China and are crappola.
btw...
>> Fuel filters, there's more than one type...
On the pickup tube of the fuel sending unit, is a plastic meshed filter screen (exc. in-cab tank). Since it rarely gets replaced, can you imagine what it looks like after 30 years?
D1AZ-9A011-A .. Filter Screen
C0AF-9276-A .. Fuel Sending Unit "O" Ring Gasket
The GAD (General automotive discussion) forum is really ONLY for those topics that don't have a regular spot on FTE to be asked.
ie:NON-Ford Trucks or Cars,Generic,Large Trucks type topics.
FTE used to frown upon the MUlti-posting of threads as well.
IMO> It is better to Post ONCE in the proper forum and if no one replies, keep bumping it to the top of the page.
This 73-79 forum is the Best Place for this topic.
Okay... finally got time to poke at the truck! I was a big fan of the ignition module idea so I put in a new Motorcraft one and there was no difference. So I went ti the carb and double checked my float levels. Seemed fine. Tried to start it and it coughs and chokes and wont idle. It is also blowing out huge billowing clouds of black smoke. (neighborers came down from two doors up to see what was going on) I put on a different Holley carb I had sitting in the shed and it acted the exact same way. I'm thinking timing or heads?
my 77 was running rough and had similar problems as yours. but when i put flowtech headers on it i realized not all of the cylinders were firing. so I changed plug wires and i was deffinately getting good spark. so i pulled a valve cover off and realized i had a bent pushrod and broken lifter that was for the intake. so i replaced them and shot it with a timing light and i had some plug wires on the wrong cylinders so my uncle labeled them. but when I went to put the plugs back on he had labeled the wires with two 3's but anyways my 400 runs alot smoother
