2.5 inch leveling kit up front. Pics in gallery. I took the stock antenna and cut it with a hack saw and replaced the bead on top. Still has stock antenna with no loss of reception. Can not tell any difference in stock antenna except it is about 2 inches shorter. Over ride height is 6 foot 5 inches at its highest point.
Even cheaper. You guys are great for saving me money.
(After viewing ADBarron gallery): Wow, you have that cockpit set up like the space shuttle.
Some pics in gallery. 2.5" AS level w/ AAL rear, 18x9 Helo Maxx 6 wheels. This required a very slight trim of the front air dam - nothing that you would notice, though. I would say that 35's would need a wheel with perfect backspace or plan on some trimming.
you can check my gallery also for the 2.5" autospring, with 325x60x18 terra grappler at's, mounted on pro-comp knight chrome 6009 series wheels... they did rub just a tiny bit, but i trimmed that and have no issues... and you can only tell that i trimmed if you are looking for it.
295/70/17 which is the biggest I could fit on my truck with minimal rubbing (only when steering wheel is turned all the way left or right). My truck is also a 4x2. You can go bigger if yours if 4x4
that looks really good man. i like the wheels also. is there still enough clearance to go out and do some wheelin'?
