351w 2 bbl throttle function?
Thanks,
Randy
One was when the air conditioning was turned on the idle was raised. AC puts an extra load on an engine and could make the engine idle down enough to actually die. I have actually had this happen with a disconnected/broken throttle kicker. Simple way around it is to just up the idle adjustment to where the RPM's at idle are always a bit to high except when the AC is on. If you don't have AC, or AC that works, you don't really care about the kicker.
The second purpose is as an anti-dieseling device. With an engine that has a very lean idle from the factory (for lower emissions) and that also runs at a fairly high temperature (also for emissions) it's pretty easy to get engine run-on or "dieseling" after the ignition has been shut off. In this case the kicker is energized whenever the engine is running and controls the idle speed. If you wanted to adjust the idle you would adjust a spring loaded screw thingy on the side of the kicker that would move the entire kicker back and forth. As opposed to just turning the more usual idle screw. When power was shut off (key turned off) the kicker would retract completely. This would allow the throttle plates to close completely, shutting off all air to the engine so it couldn't diesel. IIRC, such setups also had a regular idle screw that could be used to override a dead kicker if need be.
There may be others, these are the only two I know much about. I don't know if the two functions were actually combined in one unit, but I don't see why not. I don't recall a vacuum line to these things, just wires. So the thing could indeed be something else.
