Sponsored by: Real Truck
Got a nice used front seat, install help?
Old Jul 24, 2007 | 07:21 PM
CPT_Diesel's Avatar
CPT_Diesel
OK, I have an XL with the bench seat. I didn't like it since I am tall and can't adjust the bench.
I picked up a complete 40/20/40 manual seat from a 2004 x-cab F250 from the local salvage yard.
It looks like there are places to screw it into the floor, but I need the bolts and possibly some rubber bushings?
Does anyone have a link to a parts diagram showing the bolts, bushings etc that I can check to see what I need to order?
Also, what size torq bit do I need for the floor bolts? I bet they are really on there too...
Thanks in advance. I can't wait to get the seats in!
Old Jul 25, 2007 | 05:48 PM
CPT_Diesel's Avatar
CPT_Diesel
OK, has anyone removed their seat then?
Do you think a ford parts dept will help me order the necessary bolts and bushings to install?
Old Jul 25, 2007 | 06:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
I can't find a blowup online. Surely your parts deptment will help. I'm pretty sure you're gonna need the bolts (TORX) for the center section, left side of the driver's seat & right side passenger seat. But then again...how does the XL bench seat bolt in? Just on the outsides?
Old Jul 25, 2007 | 07:15 PM
riggz's Avatar
riggz
If they want your business they will! Alternatively you can contact one of the FTE sponsors like www.directfordparts.com or www.discountfordpartsaty2kford.com They should be more than happy to look up the diagram and get you the part #'s ordered.
Old Jul 26, 2007 | 08:05 AM
CPT_Diesel's Avatar
CPT_Diesel
All the bolt holes are there in the cab floor. They are plugged with plastic plugs so I should just be able to take them out and use them.
The bench is bolted on 4 corners and there are a few other bolts on the bottom. Being an XL I don't have to worry about the carpet and all that I'm hoping to just bolt the seat in.
I need to buy a torq bit of the right size if I can find it too. My ford repair CD has a drawing of the seat components and what torque values to tighten the bolts, but no part listings.
It looks like the seats have a rubber grommet in the back bolt holes.
I'll check around on the sponsors websites, thanks.
Old Jul 26, 2007 | 10:12 AM
Beerstalker's Avatar
Beerstalker
I've never noticed any rubber grommets on any of the bolts in my 99 or 07. I've only had super and crew cabs though. I took the seats out of my super cab many times (I had the 40/20/40 split bench). There were 4 Torx head bolts up front and 5 studs with nuts in the back. The center seat goes in first and uses the center two bolt holes up front. It shares one of the rear studs, with the passenger seat I believe, and the drivers side has its own stud (going from memory I might have that reversed). The other two seats can then be sat in place and the bolts/nuts installed. The nuts were covered with plastic covers that I threw away since half of them broke the first time I pulled them off. I will run out to my truck later and find out what size torx and deep well socket I used.
Old Jul 26, 2007 | 11:18 AM
CPT_Diesel's Avatar
CPT_Diesel
Beerstalker, thanks for the info. I was wondering if the console went in first or after the other seats.
I will have to take a look at my XL bench seat. I don't recall seening studs, just bolts.
Would greatly appreciate the torx size. I have a small set from when I owned my Harley, but nothing that big.
Old Jul 26, 2007 | 04:11 PM
Beerstalker
Should be a T55, and an 18mm deepwell if they are using studs/nuts for the rear. Looks like they switched to 18mm all the way around in my 07 (studs in back, bolts up front).
Old Jul 26, 2007 | 09:25 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
just to save you the trouble... dont go to Home Depot or Sears trying to find a T55 torx as I did. You probably have to get one off a tool truck.
Old Jul 26, 2007 | 09:40 PM
Beerstalker
I got mine at Sears. I bought it by itself, none of the Torx sets came with a T55, they all jumped from T50 to T60.
Old Jul 26, 2007 | 09:56 PM
RCKYMTN-PSD
All of the ones near me didnt have any that big
Old Jul 27, 2007 | 07:21 AM
CPT_Diesel's Avatar
CPT_Diesel
Thanks for the info again. I'll be on the look out for a T-55.
It looks like the seats came out of a truck that had an air bag deployment on the drivers side. The seat belt pretensioner went off, so I need to replace it.
According the the Ford service manual, I should also replace the buckles, belts etc.
Old Jul 27, 2007 | 01:18 PM
CPT_Diesel's Avatar
CPT_Diesel
Got a couple of quotes and two nice parts diagram from the local Ford dealership.
I had to drive by rows of brand new shiny Super Duties tho...
Bolts are about $10 each, seat belt assembly $85 (the whole buckle and pyrotechnic device that goes off when the air bag goes off).
I need to see what I can reuse from the current set up. The diagram had studs for the back holes, with nut and washer $3 each.
Now I just gotta find a T-55. I may have one, as I bought a bigger Torx set from Sears a while ago when doing some brakes.
EDIT: Looks like a significant savings thru the web site sponsors! Thanks!!!!!
Old Jul 27, 2007 | 01:45 PM
Beerstalker
What exaclty are you talking about with the seatbelts. I have neve heard of this before. I know my seatbelts lock whenever I hit the brakes hard, but I have never noticed any wiring going to them that may cause them to lock permanently. Is this something that is different in the belts that are built into the seats?
Old Jul 27, 2007 | 02:01 PM
miker67's Avatar
miker67
Sears sells a t-55 in the "Lisle" brand. If i remember correctly, Napa sells Lisle tools as well, as does O-reilly's
