PCV oil consumption
Old Oct 19, 2000 | 09:55 AM
Reuel's Avatar
Reuel
PCV oil consumption
Old Apr 6, 2001 | 10:07 AM
beartracks's Avatar
beartracks
PCV oil consumption
My new engine is sucking oil throught the PCV valve. I'm using Motorsport cast aluminum covers with no baffles. Any ideas on how to add external baffling to the PC valve/socket? I'm trying to restrict the flow with an oricfice in the filter side to develope a couple of inches of vacuum but still need some kind of baffle.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Apr 6, 2001 | 10:56 PM
Franklin2's Avatar
Franklin2
PCV oil consumption
I had a set of Mickey Thompson covers one time and they had a piece of thin brass formed to cover the inlet of the pcv valve and it was mounted with two machine screws to the underside of the valve cover. The screws showed through the top though, but maybe your valve covers are thick enough to drill and tap without going through? You also have to make sure you negotiate this between the rocker arms.
Old Apr 7, 2001 | 12:34 AM
karljay's Avatar
karljay
PCV oil consumption
I've seen wire mesh used inside the valve cover. It was folded several times and packed covered with small metal plate with a opening on one side.
Old Apr 7, 2001 | 02:46 AM
fe4ever's Avatar
fe4ever
PCV oil consumption
Just put stock covers on, with the stock baffles!
