Overdrive Button Question
Old Jul 24, 2007 | 02:24 PM
babock's Avatar
babock
When you disable the overdrive, does it keep the transmission from shifting past third gear or does it prevent lock up of the torque converter in 4th gear.
Old Jul 24, 2007 | 03:45 PM
T-B_MN's Avatar
T-B_MN
Overdrive is the 4th gear, turning it off will let you use the first 3 gears, which can help stop constant downshifting if you are towing or whatever.
Old Jul 24, 2007 | 03:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
Shifting past third.
