Doh! I was changing my fuel filter tonight and had a major flub. I was having a difficult time getting the top filter cap screwed on. I re-seated the filter a few times and everything seemed okay. So I proceeded to push down and screw the cap a bit harder. That's when I felt a snap.
I removed the fuel filter and noticed the head of the center "pilar" had snapped off (cheap little plastic thing). To see what I'm talking about it is the blue piece in the picture below:
I'm not sure how or why this would snap off when inserting the filter. I was not pushing down or turning very hard. From what I can tell, it looks like is used to prevent the fuel from back filling when removing a used fuel filter...
If that is the case, can I drive the car while this is broken and replace the center pilar piece during the next filter change? (I hope this piece is easy to replace...)
Do Not drive it like this, You must repair the broken assembly in the secondary fuel filter housing. I do not know how difficult this is to change as i have not replaced one.
Where you using OEM Racor fuel filters or will fit (ie Wix etc)?
I was using a Wix. Now that I'm reading the boards I realize this is probably a bad idea...
Yep bad idea. Wix originally repackaged Racor filters but a few years ago switched to "will fit" copies. They also do not have the white "Aqua Block" fabric on the primary filter in the frame rail.
Best place to buy the Racor fuel filters is your local IH dealer, approximately $35.
IH part # 1847170C93
Well the good news is that the assembly comes out with two easy torx screws. I'm keeping my fingers crossed that my local dealer has this part in stock.
International Harvestor-- the truck dealer. I broke my stand pipe also, using will fit filters. They just don't fit right. That piece is really cheap, and I bet it happens more than folks know.
On another note (not trying to hijack your thread Sharkus), is it really necessary to remove the fuel from the secondary housing before installing the new filter? I have not been removing it. I figure I will get more contaminates back into the housing while trying to remove it than I would if I just leave it there.
Thanks
Off Topic....I changed my fuel filters last week, and it seems the fuel in the secondary filter drained back out on it's own. I didn't have to suck it out this time.....Why would this be?
I never suck out any fuel from my upper filter housing and I've never found water here or from the water drain at the frame mounted main filter assembly since I purchased my 2004 F250 new. I'm at 106,322 miles now on the truck.
It is a good idea. I've had water trapped in there, and the only way to get it out is drain.
Do you use aftermarket fuel filters or does your primary filter have the white aquabloc membrane? It should be really difficult to get water in the upper housing unless you've got some really really bad fuel.
I do not think it's necessary to drain the secondary fuel filter unless it's contaminated as it might cause a hard to restart condition.
I use a turkey baster to remove about 1/2 of the remaining fuel in the secondary housing. It just makes it easier for clumsy-old-me to keep the SPLASH of fuel from filling my day with joy when I not so skillfully snap the new filter into place... The only downside to this method is that turkey tastes a little gamier now...
To overcome the post filter replacement hard start, just cycle the fuel pump (turn the key to run, not start) a couple of times... The pump will run... Stop, cycle the key, ya da, ya da...
On the early trucks 03 & 04 the way the supply fuel line was designed at the secondary fuel filter the fuel could run back out. With the changes made to the 05 and newer trucks a trap was added to the fuel line to prevent the fuel from running out.
F250tuff, I don't siphon out the fuel on my 06 when changing the secondary fuel filter. As long as you pay attention to what you are doing you will not splash fuel out.
I found it trivial to drain. Just use a small 6-8 ft piece of clear tubing and syphon. (Don't get it in your mouth.) Much faster and easier than a turkey baster.
sharkus, PM me your mailing address. I've got a gazillion of those little tube packages laying around from doing head gasket jobs. I'll be more than happy to stick one in an envelope and express mail it out.
