Push Button Start
Old Jul 23, 2007 | 11:38 PM
Ar15hunter's Avatar
Ar15hunter
Push Button Start
Well my 1990 F-150 is very hard to crank. I replaced lock cyl. with no help to the problem and I really dont feel like taking off the steering wheel. I decided to go with a Push button start, I already bought the part and wires but I dont know which is the ignition wire so I can splice to connect to the new push button. Any help would be great!
Thanks
Rob in TX
Old Jul 24, 2007 | 03:52 AM
dave2's Avatar
dave2
Before you do all of that, have you tried loosening the two screws on the switch itself and slide it a little (I think upwards). Mine would kill your fingers starting up, especially when it sat in the sun and the flange was blistering hot to begin with. Works like a charm now. Just have to remove the fuse access panel and the 4 bolts and steel cover under the column to access the switch. It may need replaced, but mine had just slid a little over time.
Good Luck
Old Jul 24, 2007 | 10:04 PM
Ar15hunter's Avatar
Ar15hunter
Wow that took maybe 5 minutes Thank you so much, It is so easy to start now. Now I dont have to wire in a push button start!!!
Thanks again
Rob
Old Jul 24, 2007 | 10:39 PM
Skandocious's Avatar
Skandocious
Good work Dave! I gotta give you a rep point for that one.
Old Jul 24, 2007 | 11:14 PM
Dean88's Avatar
Dean88
I'm with Chris on this one. 1 rep point for Dave!
Old Jul 25, 2007 | 10:05 AM
dave2's Avatar
dave2
Thanks again
Rob
Don't throw the switch away, just hook it up to a real loud horn and blow it everytime you see someone on a cell phone or doing something else stupid while driving...........
I like to catch nose pickers..... especially at stop lights where they can't get away fromthe embarrassment.
Glad it worked for you..
Dave
Old Jul 25, 2007 | 11:32 AM
mprice's Avatar
mprice
Dave
Anytime someone bothers me about a nose pick I just offer to share. That's just the old playground defence - refuse to be embarrassed.
Calvin
