I am reading alot about the autospring leveling kits. Anyone used the kit from Topgun customs? I plan to run 305/65 R18 BFG AT's on stock 2004 FX4 wheels. Anyone had any problems w/ this setup? Thanks
I just picked up a 2.5" ready lift leveling kit (used), are they just as good? How much have people seen the alignment get messed up. Is it something you have to drive immediatly to, or is it just a little out of wack?
Welcome to FTE a few of you . The Topgun is nothing but a knockoff of the Autospring... and it is not nearly as well constructed. Stick with the original, and you will have zero complaints (the Autospring is the hands down favorite in this forum).
So I am assuming the "Topgun" you mention is the ready lift?
I do not recognize the name 'ready lift'. There are tons of lifts out there, but none are as heavy duty as the Autospring kit. There are also a few different styles. Its a crapshoot, unless you know what to look for. Do you have a link to this other style?
Well... that is certainly a knock-off of the Autospring. I see one of the MAJOR differences, is the construction. Does that site list what grade the hardware is? I know the Autospring setup uses very heavy duty Grade 8 equipment. Who knows what this other manufacturer uses. Also, see how the top mount is nicely radiused? Sure looks nice.... but you lose a bunch of torsional rigidity that way. The thickness of the actual material is also in question here. I think that site said 1/4". I believe the Autospring uses either 3/8 or 1/2" thick. MUCH heavier duty. Also, how are the two pieces reinfoced? If its anything like the Top Gun, its simple sleeves, which not only reinforce laterally, but provide guides for the screws. The Autospring? Fully gusseted steel stock, of the same thickness as the rest of the product. You could probably level out an Abrams tank with an Autospring setup.
Oh.... and the Ready Lift is over 2x more expensive than the Autospring setup....
It is your cash, but I just try to make everyone aware of whats out there.
I am not a paid endorse for Autospring either.
I paid $58 shipped, if they don't work or look fishy, I will just re-sell them or throw them away.
What is the correct toe setting? I measured mine stock and it's actually toed out .25". I thought they were always supposed to be toed in at least a dgree or two.
is it a MUST do it right after install? or could I install in the garage and drive it down the an alingment shop.
it would be a good idea, sometimes it will be off sometimes it wont, for example ive heard of peoples being pretty off after the install, after i got done with my dads we took it up and it was still dead one, so yours may not be off but it would still be a good idea to get it done fairly quick
