Ford 150
Old Jul 25, 2007 | 06:07 AM
subford's Avatar
subford
Originally Posted by jusher
What is a TF1 module?
The TFI (Thick Film Ignition) system was an earlier name for the Ignition Module, from about 1984-1992 it was mounted on the distributor.
In your 1994 they have moved it to the Fender on the driver's side and rename it the ICM (Ignition Control Module). The diagram below still calls it the TFI Module.
It is the device that tells the Ignition Coil when to do its thing and make the spark plugs fire.
It takes information from a device inside the distributor, the PIP (Profile Ignition Pickup) sensor and the PCM (Powertrain Control Module, AKA the Computer) to be able tell the Ignition Coil when to fire.
This PIP sensor has a bigger chance of being your problem than the ICM Module (TFI). After they moved the ICM (TFI) from the distributor to the fender they do not have many problems with it any more.
The ICM.
The PIP Sensor is inside of device below and this device, the Stator is inside the distributor.
Location of the ICM (TFI).
Old Jul 25, 2007 | 06:46 PM
handyman43358's Avatar
handyman43358
Not to take over here, but Subford, can you just replace the PIP sensor? I bought a whole brand new dizzy for my truck, with the PIP already in it! D*mnit!
Old Jul 25, 2007 | 08:26 PM
subford's Avatar
subford
Yes you can buy the Stator with the PIP sensor inside it and then put the Stator inside the distributor.
Here is a link to some at Advance.
http://www.partsamerica.com/ProductL...ickup%2fStator
Old Jul 25, 2007 | 08:28 PM
handyman43358
Where could I have gotten that? I paid $100 for a new dizzy!
Old Jul 25, 2007 | 08:32 PM
subford's Avatar
subford
About $22.44, look at the link above.
But you still have take out the distributor to press off the gear and take the shaft out.
Old Jul 25, 2007 | 08:33 PM
handyman43358
I pulled the dizzy and couldn't figure out exactly how to get it all apart, so I just bought a new dizzy with the PIP in it. Oh well!
gough1
26
Aug 3, 2014 11:03 AM
Knothole
Mississippi Chapter
Nov 12, 2012 10:30 PM
Greywolf
Maryland Chapter
Feb 17, 2008 11:02 PM
Jackie M.
New Member Introductions
Mar 31, 2007 05:34 PM
JacquieMz
Jul 21, 2006 10:33 PM
