Project Truck Thread
Old Jul 23, 2007 | 05:43 PM
3Mike6's Avatar
3Mike6
Edit the title if you can, maybe sticky the thread...
I need to keep things infront of me..
What I need to do is:
Build the shackle mounts.
Bring up the RA,nuts/etc
Pushrods
Accessories and brackets
Tranny?
What else?
And waht else do we need?
I may head you way in a pickup...can't fit that MM35 in the Honda
So, if we can use this thread for moving forward on the project truck, it'd clean things up
Old Jul 23, 2007 | 07:06 PM
WillyB's Avatar
WillyB
What is MM35?
Old Jul 23, 2007 | 07:25 PM
3Mike6's Avatar
3Mike6
MillerMatic 35, my neighbor has a welder he want's to sell, and Dan needs a good one...same welder as we used on Karls fenders.
Old Jul 23, 2007 | 07:42 PM
WillyB's Avatar
WillyB
k, I C now.
What about the tranny? Did Ford ever use a 385 motor in a stock 4wd? Can we find any transmission to fit the 460 (385 series motor) that is set up for a transfer case?
Are they all special units someone has modified to fit the 385 bell and still have a 4wd tail shaft? Is it the tail shaft that makes a tranny into a 4wd?
Old Jul 23, 2007 | 10:11 PM
olfordsnstone's Avatar
olfordsnstone
Well, there was a 460 used in later model F250s. The trannie that I sent over the hill was a C-6 trans for the 460. As I remember, you just need the correct tale shaft. I will look out my way for one.
If anyone else knows differently, please let me know, so I don't go junk yard huntin' for "snipe". (a feathered creature that doesn't exist)
Old Jul 23, 2007 | 10:27 PM
3Mike6's Avatar
3Mike6
If I were a betting man, I'd bet the tranny we have, alng with what Dan has, would make up the whole sha-bang.
I/e, I know on TH350/400, the tailshaft is removed for the t-case to bolt too, but I didn't look closely at the one that Dan had, so I'm not sure...
Old Jul 24, 2007 | 08:53 PM
TigerDan's Avatar
TigerDan
The tailshaft is different from 2WD to 4WD, but of course we already have one. We have all the correct internals, they're just in the wrong case. Yes, the 2WD tranny that came with the engine will work if our internals are used in it's case.
Old Jul 25, 2007 | 05:32 PM
3Mike6's Avatar
3Mike6
Well, pushrods arrived today, so I'll start gathering things up in a box and make an inventory of what I'm taking back to Dan's, gives everyone a chance to say "Hey, you forgot..."
I'll also steam off a few things too, hate to see Karl get the job and have to wash them big fuel tanks again
Old Jul 25, 2007 | 07:44 PM
WillyB's Avatar
WillyB
How about cleaning off some better looking valve covers?
Man, is that engine ugly! Whose idea was it to paint part of it GM red? They have it on sale at the local five and dime?
Lets go Ford blue with some chrome and some aluminum! Black for the tranny and transfer case.
Old Jul 25, 2007 | 07:51 PM
TigerDan's Avatar
TigerDan
Mike's steam cleaner crapped out so he wasn't able to finish cleaning the block. The heads are as he got them, and it appears to me to be Ford red, not GM. I always paint my engines Ford red when I build them, but I didn't build this one. Perhaps the group should decide what color(s) to paint it.
The valve covers are pretty trashed, (one is anyway) we'll have to find another pair or pop for some aftermarket ones. Stamped steel chrome covers can be had pretty cheap, probably 25 or 30 bucks for the pair.
Old Jul 25, 2007 | 08:06 PM
3Mike6's Avatar
3Mike6
I'd never seen "Ford Red" before, I just assumed the PO of the heads had an engine color to match his build.
Hey, I was only paid to put it together, not make it look purty
Besides, shi_ and shine do not win races...
Old Jul 25, 2007 | 08:18 PM
AnOldDog's Avatar
AnOldDog
I have always thought there was a certain "charm" to a mixed bag of colors. Especially if it runs like a BEAST!! That intake manifold looks pretty nice though, doesn't it? If it is important, I can send down a set of chrome valve covers. It is only about $50...
http://store.summitracing.com/partde...5&autoview=sku
Just a thought.
Old Jul 25, 2007 | 08:42 PM
WillyB's Avatar
WillyB
Na, it is not important - we can watch the swap meets and find some. I sure like the big square aluminum ones that say "built Ford tough" or "Cobra Jet" Some of the chrome ones look cheesy, worse than the stock stamped steel ones.
OK, we can let the group pick the color. But the first time someone asks me if we are running a GM big Block, out comes the blue spray can. When did Ford run a red engine?
Old Jul 25, 2007 | 08:51 PM
TigerDan's Avatar
TigerDan
On the old Y-blocks. Like I said, it's what I always use when I build an engine:
Old Jul 25, 2007 | 08:52 PM
3Mike6's Avatar
3Mike6
Gotta be honest, I never knew they did, ofcourse Ford Blue and Black, are the only factory colors I've ever known.
I could give you approximate years when the General changed a few colors though
