Sponsored by: Real Truck
Death Wobble question
Old Jul 23, 2007 | 01:53 PM
UGA33's Avatar
UGA33
I have seen the topic talked about on the forum but what exactly is it, what parts cause it, and what years are effected by it?
Old Jul 23, 2007 | 02:21 PM
kw5413's Avatar
kw5413
In some cases it was just the tires.
Old Jul 23, 2007 | 02:36 PM
dbm04F250's Avatar
dbm04F250
I found with my 04 that the extreme play was coming from a number of places. I replaced the front steeing link arms, and the front sway bar bushings had a lot of slop in them, the vertical links were practically worn out and I still need to go back and replace the upper frame mounts where the vertical links attach to. This is where most of the popping and loose rattle noise was coming from as best as I can tell. No real help from the dealer about this.
