trailer electrical plug replacement (factory?)
Old Jul 23, 2007 | 05:23 AM
RUSTANG67's Avatar
RUSTANG67
I have a 94.5 F250. I was going to replace the trailer plug, but I noticed the old plug might be a factory installation. The wires have odd solid ends that slid into the existing plug, and the rubber boot that slides over the back of the plug has a Ford emblem on it.
I don't want to cut up the wires to use the generic plug I bought. Is there a replacement plug that will accept these existing wire ends?
Old Jul 23, 2007 | 08:17 AM
Franklin2's Avatar
Franklin2
I don't know of any. I would go ahead and redo it with the aftermarket plug myself.
Old Jul 24, 2007 | 12:29 PM
lsrx101's Avatar
lsrx101
If the original connector isn't corroded or damaged, there are plug in adaptors for various trailer connectors. Check with a local RV supplier. They can get pricy (~$30), but are much better than replacing the original connector and compromising the existing wiring.
