Fuel return line?
The only good chevy is a dead chevy
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Can see both below.
I had two 3/8th line running from the regulator to my 850 DP Holley, I removed them and went to one 1/2 line off one side run to the carb. then to a fuel log, and a 3/8th line run back to the tank. When I first turned the pump on I only had 2 LBS. line pressure, So I took the 3/8th Brass line barb off and taped it so I could Screw a 1/4" bolt into it with red locktight and cut the extra off flush with the end of the fitting, once it set up I drilled a 1/8" hole in the bolt, when I turned the pump on again I could now set the pressure at 7 psi to the carb. with lots of adjustment left.NOw my pump run steady without laboring against it self...
Daniel G. Homa
