water temp question
Old Jul 22, 2007 | 11:44 PM
hedhntr's Avatar
hedhntr
water temp question
1997 psd. Just installed the 203 thermostat because I thought the old one was stuck because the needle would just barely raise in to the normal mark. After the 203 thermostat same readings on the gauge. My 02 psd runs half way and a few other ones I know run half way. What does a person do. Any Ideas?
Old Jul 22, 2007 | 11:51 PM
wreckit72's Avatar
wreckit72
The stock gauge is not very accurate. You can install an aftermarket temperature gauge to get an accurate reading.
Old Jul 23, 2007 | 12:17 AM
hedhntr's Avatar
hedhntr
Thats kinda what I figured. Thanks for the reply.
plowhand's Avatar
plowhand
Playing in the Dirt
wreckit72 is correct. The stock gauges in our trucks are just idoit lights with a needle. The sending unit sends a voltage signal to the PCM which interperts the signal and then sends a seperate signal to the gauge to cause it to register. If you really want to know what your truck is doing you need after market gauges.
Old Jul 23, 2007 | 09:15 AM
Neal 97 250's Avatar
Neal 97 250
I agree with what they said> mine runs at "O" on normal.
