Cam Position Sensor choices
Old Jul 22, 2007 | 09:18 PM
iprman's Avatar
iprman
Anyone know which CPS to use? There appear to be 4 choices: the original Ford black one for $190 a new Ford black one for $23, a blue one for $190 (Inernational Harvester part no.) and a Ford gray one for $23. All different part numbers and claim to be for the 2000 F250 7.3L Powerstroke. I'm confused.
Old Jul 22, 2007 | 09:24 PM
Badluck's Avatar
Badluck
just he orignial is good i think
Old Jul 22, 2007 | 09:26 PM
yamaguy's Avatar
yamaguy
the $23 one is good as well.
Old Jul 23, 2007 | 05:58 AM
Supercab's Avatar
Supercab
I have heard that the NEW gray Ford one is better by far, they say it has brass on the elect. connections?? plus upgraded inside too!!
Old Jul 23, 2007 | 06:25 AM
15 and 92 Dad's Avatar
15 and 92 Dad
Use the new gray! The Blue is SUPPOSED to be better, I know a couple of people that bought the blue and now wished they had bought the grey!
Rich
Old Jul 23, 2007 | 08:46 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I have one of each.
Took the blue out at the advice of Diesel Innovations. Doesn't play nice with tuners.
I have a black in now and a gray as a spare.
I would use gray if I had to replace.
Old Jul 23, 2007 | 09:48 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I have 2 blacks, and 2 greys. I am running the $23 dollar grey right now. Idle seems a little smoother than the black, but most likely my imagination. DO NOT SPEND $190 ON A FORD UNIT UNLESS MONEY DOES NOT MATTER TO YOU! Get the grey,
Old Jul 23, 2007 | 09:50 AM
F250_'s Avatar
F250_
Gray installed. Runs without a hitch. Used it to replace a working OEM black unit, and now the black one rides in the glove box as a "verified good spare". Lots of folks in ehre have bought the new gray one and I haven't seen the first inkling of a problem with it from anyone. Given that, it doesn't make sense to spend more than required for the new low cost gray unit. Shoot, I'm even considering buying another spare one to have that I can offer to a stranded PSD owner who needs it.
Old Jul 23, 2007 | 09:51 AM
Powerstrokedlariat
thats the same reason I am carrying a few with me, happy to help a fellow oil burner.
Old Jul 23, 2007 | 10:00 AM
rufntuf's Avatar
rufntuf
I am new to this forum. I have a 01 f250 cre cab with 91,000 miles on it. The Ford dealership thinks my CPS is going out since my will start and run fine, after about 10 min. it die for a split second. If you are running down the highway it will just hiccup, but if you are idleing it will die. Where do you purchase the gray CPS and how difficult is it to install?
Thanks
Old Jul 23, 2007 | 10:07 AM
TraderJ's Avatar
TraderJ
I bought mine off ebay...$49.99 for 2 of them including shipping...the are both gray.
One's in my truck ...gave one to my Dad for his ( He will thank me oneday!)
Old Jul 23, 2007 | 10:14 AM
Texas Outlaw
Not a liberal...
Thanks
Piece of cake to change. Takes longer to round up the tools than it does to change. Here are the instructions:
http://guzzle.rbmicro.com/cps.html
Old Jul 23, 2007 | 10:17 AM
twjull's Avatar
twjull
I bought 2 for $100.00ea at International in Phoenix a year ago. Since when was one avaible for $23.00??
Old Jul 23, 2007 | 10:22 AM
af4ms's Avatar
af4ms
Thanks
I bought my new one from:
http://fordparts.com/cart/?pn=F7TZ-1...&submit=Search
It is easy to install, access from underneath the front passenger side of the engine. It is located next to the belt pully on the lower side of the front of the engine. A 10 MM wrench (or small socket) and about 10 minutes. The sensor comes with a bracket. Remvoe the plug, single bolt, and pry out. You may want to put a little oil or vaseline on the new O-Ring and it will go in easy. Put the bolt back in and pulg the connector back and you are good to go.
Good Luck,
Doug
Old Jul 23, 2007 | 10:26 AM
HKusp's Avatar
HKusp
I bought mine from here.
http://catalog.powerstrokeshop.com/p...catalogid=3660
I also bought the fuel filter to have a spare. I think it was $41 for both shipped to my door.
