Stalling problem
Old Jul 21, 2007 | 06:18 PM
Splash78's Avatar
Splash78
Stalling problem
Trucks stalls every now and then when ether slowing down or at a stop. Doesnt do it all the time. Sometimes it idles rough at stops other times it doesnt, nothing consistent. Have replaced entire fuel system tanks, sending units, filters, etc. EGR valve is removed and plugged. Checked all vacuum lines and they all look in good shape. Any other ideas as to what may be causing this? Plan on changin plugs, wires, distributor and rotor next. In the mean time have poured a can of seafoam in the two tanks and will see if this helps. Open for other suggestions.
1984 F250 351W 4BBL 4WD
Old Jul 21, 2007 | 07:00 PM
Franklin2's Avatar
Franklin2
If your carb has the site plugs in the passenger side of the carb, make sure your fuel level is at the bottom of the site holes front and rear. If the fuel level is a little high, when you hit the brakes, fuel can slosh down in the engine and make it stall.
