2 speed T-case
Old Jul 21, 2007 | 05:42 PM
79_250RangerLariat's Avatar
79_250RangerLariat
2 speed T-case
Can anyone give me some info on my cousins truck. It's a 86 250 ex cab 2wd 8'bed 6.9 4speed but it has a 2 speed T-case behind the trans. The 2 speed started clunking yesterday so he hasn't been running it. Is the 2 speed a chain drive or gear on gear? Any other ford trucks come with the same case if his is junk?
Thanks
I've been doing some more searching and all I can figure is maybe it's a gear vendor....
Old Jul 21, 2007 | 07:10 PM
Franklin2's Avatar
Franklin2
Have you figured out why it has a transfer case, but it's only 2wd? Transfer cases were only used on 4wd. Does it have a spot on the front to hook another driveshaft? If it doesn't, then it's not a transfer case.
Old Jul 21, 2007 | 08:27 PM
Big John Hance's Avatar
Big John Hance
I've never seen a 2wd with a transfer case before.
Old Jul 21, 2007 | 09:09 PM
82F100SWB's Avatar
82F100SWB
Being a diesel, I'd venture to say that it's probably an aftermarket over or underdrive under there, and not a transfer case.
Old Jul 21, 2007 | 10:50 PM
f100beatertruck's Avatar
f100beatertruck
Unless someone needed a trans and had a 4x4 unit and swapped it in... Verify that it does or does not have a front yolk.
Old Jul 21, 2007 | 11:06 PM
79_250RangerLariat
Nope no front yoke, I was just calling it a T-case for the lack of a better word. Couldn't remeber gear vendor till after I did the inital post.
Old Jul 22, 2007 | 08:04 AM
Franklin2's Avatar
Franklin2
It probably is an aftermarket overdrive unit, Ford never offered one. I believe they are a planetary gear system like an automatic tranny has. They are supposed to be bullet proof. I wonder how much oil it has in it?
Old Jul 23, 2007 | 08:11 PM
79_250RangerLariat
Update:
Talked to my cousin tonight and he's been dealing with the local ford dealer. It seems that in 86 they did have a 2 speed t-case for on the 2wd diesel... They even had the info on file, just no info on wether parts were still available.
Old Jul 23, 2007 | 08:23 PM
Franklin2's Avatar
Franklin2
Learn something new everyday.
Old Jul 23, 2007 | 08:25 PM
ri_truck_guy's Avatar
ri_truck_guy
What would be the use of something like that?
Old Jul 23, 2007 | 08:31 PM
82F100SWB's Avatar
82F100SWB
Weird, I have never heard of such a thing. Get us some pics if you could.
Old Jul 23, 2007 | 11:56 PM
johnsnewtruck's Avatar
johnsnewtruck
wtf
this thread makes no sense at all
Blame it on the 30 year old whiskey I am sippin
there is no point at all of a tcase on a 2wd the rwd driveshaft is a direct connection, no gearing at all, right?
i just was looking at one like 30 mins ago, but again with the whiskey...
Old Jul 24, 2007 | 05:48 AM
79_250RangerLariat
I don't see how it would be much different than a 2 speed rear end, or using a GV over/under. I for an example put your 4x4 t case in 4 low but leave the front hubs out. You still get a gear reduction to the rear end (granted the front is spinning but with the hubs out that's all it's doing). I don't know what the reduction is thru the case (i'll try to find out) but any reduction would help when pulling something heavy in hilly areas...even with a 2wd
I know in my 75 Ford 800 dump truck w/out the 2 speed rear I'd take for ever going up hills loaded.
