351w heads. Diff bolt patterns? Please Help.
Old Jul 4, 2001 | 02:45 AM
FastPony's Avatar
FastPony
Hey, I'm 14 and in the middle of my first ford build up (1979 4x4 with 69 351w). I bought some custom fit headers for my truck but the bolt pattern was way different. Can I get headers that will fit my truck AND my engine, and if not (sucks that i will have to get rid of the 69 heads due to their high compression),what years of heads used the same bolt pattern as the 79 351w. Any help on this subject would be much appreciated. Thanks.
Old Jul 4, 2001 | 07:17 AM
DeenHylton's Avatar
DeenHylton
I'm not totally sure on the small blocks since I gave them up years ago for the big torque monsters (460 or bigger)...but are you SURE you didn't buy headers for a 351M-400M instead of a 351W
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Jul 4, 2001 | 07:42 AM
Nathan's Avatar
Nathan
I agree, I dont recall any changes in the smallblock (W) exhaust bolt pattern, only a change in head bolt size in '77 or so. Id check the application, maybe the wrong headers were put in the right box.
Nathan
Old Jul 4, 2001 | 11:23 AM
FastPony's Avatar
FastPony
Thanks. The bolts on my new headers, insteaad of being straight across from one another, they are kind of staggered (one on top, then, one on bottom, so on and so on). Is this what a 351m is like? Do you really think I have the wrong ones? Hope this info helps. Thanks.
Old Jul 4, 2001 | 02:47 PM
Franklin2's Avatar
Franklin2
I got the impression those year trucks with 4x4 never came with 302/351w. Only 351m/400. So, you won't find standard headers for that year with a 351w.
Old Jul 4, 2001 | 07:31 PM
FastPony's Avatar
FastPony
You guys are right. Their the wrong headers. I'll send these back. I know the factory exhast manifolds suck so what should I do. What are the best headers that will for my setup?
Thanks everyone.
Old Jul 4, 2001 | 07:34 PM
FastPony's Avatar
FastPony
I forgot to mention that yall were also right that the 351w did not come in the 79 f-150. thanks again
Old Jul 5, 2001 | 09:12 AM
4byford's Avatar
4byford
You might try small block shorty headers; they might fit- used stock Mustang headers are easy to find for a test fit, then you can buy the better aftermarket ones if they work.
Old Jul 10, 2001 | 10:49 PM
bountyhunter's Avatar
bountyhunter
What about headers for a 302. I think they would have the same bolt pattern.
Old Aug 2, 2001 | 11:00 PM
71swissaqua's Avatar
71swissaqua
I think this post is old but maybe you'll see it. I'm pretty sure the windsor changed bolt patterns on the heads in "74" or on the first year of the egr valve. At least I know the intake bolt patterns are different between pre-egr and egr.
Old Aug 3, 2001 | 09:22 PM
bigsnag's Avatar
bigsnag
ColtonMullis
24
Jun 6, 2016 08:39 PM
compman
Jun 30, 2008 06:42 PM
captainkirk
Engine Swaps
Dec 9, 2005 12:13 PM
MikeS
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 28, 2001 11:16 AM
64 f100
Jul 4, 2001 11:32 AM
