Oil Pressure Question
Old Jul 21, 2007 | 06:08 AM
tjcnok's Avatar
tjcnok
What is the proper oil pressure for a 1955 Ford 292 V8 engine be at running timperature, both idling and at working speeds? Thanks!
Old Jul 21, 2007 | 08:46 AM
arctic y block's Avatar
arctic y block
I don't know what the factory specs are of hand. But on my Y's as low as 10 psi at idle is acceptable to me Although the more the better here. As Y's of this vintage had a problem getting oil to the rockers. 30 to 50 is good at WOT or even at highway speeds. JMHO
Old Jul 21, 2007 | 01:48 PM
tjcnok's Avatar
tjcnok
OK. Great! Thanks a lot. I guess I'm ok there as I am registering 10 at idle and 40 at running speed when the engine is hot. Whew! Thought I had a major oil pressure problem to cope with.
Old Jul 22, 2007 | 01:39 AM
HT32BSX115's Avatar
HT32BSX115
My 57 Ford Fairlane used to peg the 80psi oil pressure gage when cold.
When it warmed up it did about 30 at idle and 60+ at higher RPMS.
Cheers,
Rick
