lifting
Old Jul 20, 2007 | 01:41 PM
86fn150's Avatar
86fn150
lifting
on my 86f150 4x4 i'm puttting lifting blocks in front susp(under coil).was told all i need to do is undo shocks and lower suspension.? on lower mount -is there a bolt down retainer or does it just sit in perch?
thanks in advance,
andy
Old Jul 20, 2007 | 01:49 PM
ri_truck_guy's Avatar
ri_truck_guy
There is a 1 1/8" nut on top of a large round retainer that holds the spring to the top of the radius arm/I beam assembly. How much lift are you thinking of adding? Too much lift without lift brackets and a longer pitman arm can mess with the steering geometry.
Old Jul 20, 2007 | 02:04 PM
86fn150's Avatar
86fn150
guess i didn't mention that i'm just leveling front out.lifting blocks are 1.5-1.75 .should be just enough to level truck. thanks for the reply
Old Jul 20, 2007 | 02:10 PM
stumpbuster's Avatar
stumpbuster
Unhappy
who did you get your spacers from? daystar?
i thought you would have to put them (on top) of the coil;
Old Jul 20, 2007 | 02:23 PM
86fn150's Avatar
86fn150
not sure of brand(made in china stuff).they can be installed between coils or bottom.i'm gonna have to look at them again being that bottom of coil is bolted down
