Another Chewbacca problem
Old Jul 19, 2007 | 11:22 PM
rsjaffe's Avatar
rsjaffe
Unhappy Another Chewbacca problem
OK, so I get the Chewbacca sound from my driver's window.
Soon after that sound starts showing up, the window sticks--if I help it, it will start moving again. Finally, the window stalled completely--fortunately in the closed position.
Besides lubrication (which I will start with), are there other problems that can cause this, such as dying motor, or broken regulator?
When I press the "down" button the car's voltage drops significantly.
Thanks.
Old Jul 19, 2007 | 11:24 PM
armyboy's Avatar
armyboy
motors going bad
Old Jul 19, 2007 | 11:28 PM
armyboy's Avatar
armyboy
sorry for the short post didnt mean to... anyways i had a 92 f250 and the motors were bad.. a buddy had a 94 f150 and his motors went bad.. these trucks just seem to not like the factory motors
Old Jul 19, 2007 | 11:55 PM
Dean88's Avatar
Dean88
Yeah, my grandfathers 94 F250 burned up both of the motors in it withen a week from each other, and then it rained about 3 inches with both windows stuck down!
Before the motors went out, they made the chewbacka noise as well.
Old Jul 20, 2007 | 12:39 AM
lv2race's Avatar
lv2race
The motors have nylon plugs that break up and brushes that go bad, thats it. You can do it yourself and get brushes for cheap and nylon dowel rods at Homey Depot for a couple of bucks. New motors at the parts houses are about $80 to $90.
Old Jul 20, 2007 | 03:50 PM
93XLTFlareSide's Avatar
93XLTFlareSide
Oh Jeez, you guys jynxed me or something. After reading these Chewbacca window threads here, I was thinking to myself...hmm my power window squeeks a little but Ive never had any issues with them. Well guess what, now I need to grab the window and help it up to close if its being raised from the fully down position...it like gets stuck and kinda like makes clunking noises almost like something is slipping!
I guess this isnt the first time the power windows had issues on this truck, the original owner said that when he first got it both sides crapped out with in the first 2 months and Ford replaced them with upgraded motors. Well they worked damn good for the next 14 years...just now they are crapping out. I wonder if I should do the passenger sides while Im at it, that one seems to be working fine at the moment but I suppose that will be crapping out sooner or later!
Old Jul 24, 2007 | 07:44 PM
unleashed's Avatar
unleashed
spray some white lithium grease on the rollers and tracks.Also check rollers,I've had them wear out before.
Old Aug 5, 2007 | 01:01 PM
rsjaffe's Avatar
rsjaffe
Thumbs up
Just a follow up.
It was the motor. Unbelievably difficult to change the motor, as it is mostly hidden behind sheet metal. Kept on dropping screws down inside the door, but eventually became facile at fishing them back out. Once I changed it, though, the window worked great, except....
Some doofus who assembled the replacement motor wired it backwards! Up now meant down and down meant up. Fortunately I tested it prior to reassembling the door. Ended up having to swap the wires in the electrical connector. Let this be a warning to anyone else replacing the motor--check before closing everything up.
Old Aug 5, 2007 | 01:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Don't replace the entire motor if the plastic gear is bad (stripped). 85% of the time that's the problem. The gear kit is available from Ford, NAPA and other parts stores. It fits ALL Ford cars and trucks 1970/1996 (and maybe later).
D0AZ62234A24B .. Power Window Motor Plastic Gear Kit
NOTE: It may not be a bad motor at all. The squarish plastic window roller that bolts on the end of the regulator arm and slides in the window channel, may be broken...it's available everywhere. A 3 buck part.
Old Aug 5, 2007 | 01:14 PM
Liemavick's Avatar
Liemavick
If you ever have to go back in to get after the motor, pop the access holes to the bolts first. Look on the sheetmetal blocking your access to the screws and you'll see some indents, punch marks. Drill a 1/2" hole at each of them and you'll be able to get straight at the bolts with a 1/4" drive socket. Thats how it is in my '90, I'm assuming yours will be the same.
B
Originally Posted by rsjaffe
Just a follow up.
Old Aug 5, 2007 | 08:27 PM
rsjaffe's Avatar
rsjaffe
Yeah, I did drill the access holes and use a socket through them. I just kept losing the screws as they'd fall out of the socket. Also, maneuvering the old motor out and the new motor in was quite a challenge. You're working through a pretty small hole.
Old Aug 5, 2007 | 08:42 PM
Liemavick's Avatar
Liemavick
When you install the motor use a small piece of electrical tape to hold the screws onto the socket. With the window up you can access the motor easier I found through the large opening to the right, removing the armrest bracket clears the path....next time ;-)
Old Aug 5, 2007 | 09:07 PM
91 F-150 Farm Truck's Avatar
91 F-150 Farm Truck
I got manual windows... No motors to break...
