My friend wants to put a 390 in his '67 mustang that now has a 302. I know that some stangs came with 390s so this should fit, right? Anybody know of any problems?? Thanks in advance. Bill
'70 F-250 Camper Special 360/C-6, 3.73, 8 mpg uphill or down
A 390 will fit in a '67 with no problems. All you need is the motor mounts for a FE in a 67. Go to the forums at http://www.vintage-mustang.com and guys there can tell you where to find them.
Stryder
I'd rather be walking through a hot desert carrying a Ford hubcap than driving a POS Chevy
No problems...but you will need a big block tranny either auto or stick, big block front springs, H.D. radiator, mustang 390 exhaust manifolds or aftermarket headers, 9" ring gear for longevity, etc., etc.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Bill, you will also need to swap in the front sway bar from a FE Mustang otherwise the oil filter will hit the smallblock swaybar. The bigblock sway bar is bent differently in order to clear it.
[QUOTE]My friend wants to put a 390 in his '67 mustang that now has a 302. I know that some stangs came with 390s so this should fit, right? Anybody know of any problems?? Thanks in advance. Bill
Tell him to get a 351C-4V instead. Everything fits except the radiator outlet. Also he will get more horsepower with less weight.
