Loud fan noise when accelerating
Old Jul 19, 2007 | 09:18 AM
Mr.BrrIce's Avatar
Mr.BrrIce
I have a 04 FX4, driven about 35000 miles.
Last weekend, when I was driving normally on a flat road doing 50-60 mph, suddenly I hear this loud "fan-like" noise when I accelerated abit, then it went away again.
This happened again and then I felt like the truck lost abit of power and didn't accelerate normally. Still it kept cruising speed and I was able to accelerate abit.
This loud "fan-like" noise is only heard when the AT is in steps 1-3 but not in the OD (4th). The truck accelerates but not as before and I not pushing it, just normal acceleration. The rpm looks normal, meaning it's not jumping up relative to the noise.
I was thinking maybe it would be the converter not locking up, but it holds very well in OD.
I have checked the oil, the AT oil and other fluids. All gauges are normal.
I would really like to hear what this could be?
Regards from Iceland
Old Jul 19, 2007 | 09:55 AM
Shane07XLT's Avatar
Shane07XLT
It's your clutch fan engaging. Check your cooling fluid level.
Old Jul 22, 2007 | 07:48 AM
Mr.BrrIce's Avatar
Mr.BrrIce
My cooling fluid level is normal as are all other fluids and gauges.
This loud fan noise can now always be heard exept when driving in OD (4th step).
Is this something that can be fixed or is this another problem.
Old Jul 22, 2007 | 11:13 AM
SUPERDUTY_untouchabl's Avatar
maybe it was just a little hot what was the temprature out side?
Old Jul 22, 2007 | 11:41 AM
kd4crs's Avatar
kd4crs
There was a TSB for the 04s that pertained to fan clutch noise. There is an updated fan clutch for them, I had mine replaced under warranty. The noise on mine was most noticable at cold startup during fast idle. It is TSB 05-4-3 listed in the Recalls/TSBs section.
Old Jul 24, 2007 | 06:02 AM
Mr.BrrIce's Avatar
Mr.BrrIce
Thanx for the replies and the info, guys.
I went to the Dealer and they confirmed that it was the Fan Clutch.
I have bought a new one and will replace it myself since my truck is no longer under warranty.
This is my second failure in this car after driving almost 40k miles. The first failure was a worn-out tie rod
I am very happy with my truck and I have been doing alot of off-roading.
You can check out my website: www.trukkurinn.com and under Myndir (on the left which translates: pics)
It's all in Icelandic but there are alot of pics there in an album called Jeppaferdir (translated: Off-road Traveling)
THX again for the replies.
Old Jul 24, 2007 | 06:48 AM
jstnromero's Avatar
jstnromero
hmmm i need to take my truck in....having the same noise... thanks for the heads up
Jayslow
1997 - 2003 F150
Sep 4, 2014 07:39 PM
hilio
6.4L Power Stroke Diesel
Nov 14, 2013 08:41 PM
RadRick
Modular V10 (6.8l)
Sep 10, 2013 12:32 AM
al1270
Dec 14, 2010 10:24 AM
celronart
May 28, 2009 09:22 AM
