Help, tranny/speedo coupling
Old Jul 19, 2007 | 12:56 AM
tbm3fan's Avatar
tbm3fan
It seems that I am leaking quite a bit of fluid out of the speedometer cable where it goes into the C-O-M. What needs to be done to correct this problem as it is as tight as it will ever be...?
Old Jul 19, 2007 | 08:19 AM
Flyn66dtmn's Avatar
Flyn66dtmn
The biggest possibility wll be the O-ring around the piece that slides into the transmission. easily repaired. the other possibility will be a separation where the cable meets the head that goes into the tranny. have never heard of this happening but it may be a possibilty if it has been bent around enough to weaken it. dutch
Old Jul 19, 2007 | 04:41 PM
tbm3fan's Avatar
tbm3fan
O-ring? What are the odds that part is very obsolete or is it possible the part number can be cross referenced?
Old Jul 19, 2007 | 05:04 PM
jowilker's Avatar
jowilker
O-rings are round rubber washers (round not flat) and very obtainable from most anywhere.
John
Old Jul 19, 2007 | 06:57 PM
tbm3fan's Avatar
tbm3fan
iI know, you just have to match OD, ID and thickness...
