? about more power
Old Jul 18, 2007 | 08:03 PM
kincartEC73's Avatar
kincartEC73
? about more power
I have a 95 f150 w/ a 300 strait 6, dont get me wrong, its got plenty of *****, but would i get more power and better fuel economy with a throttle body spacer and a cold air intake?
Old Jul 19, 2007 | 12:33 AM
zbollman's Avatar
zbollman
Don't know how well throttle body spacers work, but intake will probably give you more of a response increase by allowing it to gather masses of air quicker. Headers are the quickest gain without rebuilding the engine.
Zach
Old Jul 19, 2007 | 12:52 AM
I6power's Avatar
I6power
Neither will do much.
Old Jul 19, 2007 | 08:53 PM
F-150battlemaster's Avatar
F-150battlemaster
Cold air intake is good for power but reduces mileage a bit. Forget the exact rule of thumb but I think if you reduce the intake temp by 1deg you get a 1hp increase. So like I6 said. Not much but every little bit helps.
Spacers either work or don't depending on who you talk to. The dyno results in the advertisements show improvements. About the only way to collaborate that is to dyno your truck before and after to see if there is a difference. Same thing with tornado's.
Old Jul 22, 2007 | 03:40 PM
89straightsix's Avatar
89straightsix
Cold air intakes aren't even worth it. I used to have a K&N FIPK on my '89. It didn't do anything except make a sucking noise. That was the worst $200 i ever spent, just my opinion.
Old Jul 25, 2007 | 04:40 PM
JL63's Avatar
JL63
On my uncles old tundra it made a pretty big difference in power and response with the filter charger...but thats a totally different truck...
Old Jul 31, 2007 | 12:19 PM
compaddict's Avatar
compaddict
https://www.ford-trucks.com/forums/5...installed.html
Vince
