5.0 engine question....
Old Nov 8, 2001 | 05:08 AM
TexasGuy001's Avatar
TexasGuy001
I have a 1995 F150 5.0 2WD automatic. I saw that Ford Motorsports offers a 345 hp 302 w/ aluminum heads. My question is can I swap my factory 5.0 engine with this one without any problems???
Thanks
Old Nov 13, 2001 | 01:01 AM
StangMan's Avatar
StangMan
Are you talking about the GT40 crate engine? If I remember right, it had GT40P heads, which you will run into problems with because the header ports are different. The "P" heads require a special header.
Otherwise, it should work fine.
Hope that helps,
Ben
Old Nov 14, 2001 | 09:04 PM
Franklin2's Avatar
Franklin2
