Runs rich
Old Jul 17, 2007 | 08:51 PM
FlairSide's Avatar
FlairSide
Runs rich
Seems like when I fire up the truck it runs ruff and black smoke out of the tail pipes. After a while it smooths out. Almost could say it seems to be missing at first fire up. Is it possible there is a leaky injector? Also sometimes engine stalls and you need to floor gas pedal to get truck to start. Also seems like much black smoke. The truck has a new TPS and I cleaned the IAC. It also has a new temp sensor for the computer. It has a cam but is not agressive as it is a 92 302 with a maps setup.
Old Jul 18, 2007 | 12:16 AM
pmipmatt73's Avatar
pmipmatt73
ive heard of bad fpr (fuel pressure regulator) causing black smoke to come out of tailpipes.
im pretty sure u can test it by pulling the vacuum line from it and turn the key to the on position. if it leaks out any fuel it is bad.
Old Jul 18, 2007 | 01:35 AM
Fordpup's Avatar
Fordpup
My 89 did the same thing Flairside. I tested the fuel pressure at the rail, and at idle, she was pushing 100+ lbs. She also was blowing black smoke, especially when I revved her up to "clear her throat".
I changed the FPR, fixed the prob right away. Check your fuel pressure at the rail.
Hope this helps......
Old Jul 18, 2007 | 02:11 PM
FlairSide's Avatar
FlairSide
Thx for the suggestions I will do that tonight.
High76boy
Jun 17, 2014 06:06 PM
linus72
Apr 16, 2012 07:40 AM
Jasonszion
Jul 30, 2011 11:16 AM
GPSMatt
Nov 4, 2005 08:55 PM
bricktop
1983 - 2012 Ranger & B-Series
May 8, 2004 09:00 PM
