radio removal?
Old Jul 17, 2007 | 06:16 PM
SUPERDUTY_untouchabl's Avatar
Question radio removal?
Does the black part around the stereo come off or does the whole dash half to come off? I figure the black part will just pop off but I am just wanting to make sure. thanks.
Old Jul 17, 2007 | 06:51 PM
soxfan81's Avatar
soxfan81
yes it will pop off I think I started at the bottom and worked my way up.
Old Jul 17, 2007 | 06:58 PM
Big Daddy 18C's Avatar
Big Daddy 18C
Somewhere in the Brandmotion iPod thread (https://www.ford-trucks.com/forums/5...d-adapter.html) there is an explanation on how to remove the radio cover.
Simply put, open the cup-holder partially, work your fingers under the cover and begin prying it off. It feels like it will break when you first start, but eventually it comes off.
Old Jul 17, 2007 | 07:09 PM
Sweetness thanks guys.
Old Jul 17, 2007 | 08:25 PM
FTE Trigger's Avatar
FTE Trigger
You should be able to find quite a few threads on this very subject a here in the forum...
Btw... when you do take the bezel off, don't forget to put the metal clips back in the dash prior to re-installing. (You'll see what I'm talking about when you pop it off)
Old Jul 18, 2007 | 09:39 AM
champ7718's Avatar
champ7718
My truck has an ash tray below the radio cover, has anyone removed this before? I'm having some difficulty getting it out...
Old Jul 18, 2007 | 11:47 AM
FORD7445's Avatar
FORD7445
I think there is 2 screws in bottom
Old Jul 18, 2007 | 04:25 PM
FTE Trigger
Curious... are you removing the ashtray, just to remove it? It shouldn't be necessary for the radio bezel removal.
Old Jul 19, 2007 | 01:11 PM
champ7718's Avatar
champ7718
Actually I'm modifing the ash tray into a IPOD dock, went and purchased all the PIE gear to use the proprietary IPOD dock but it results in just a loose cable that is typically routed to the glovebox. I'm going to take out the ash tray and make some modifications so when it opens I've got a IPOD dock right there to plug into. Not a smoker so I won't be missing the ash tray at all.
Old Jul 19, 2007 | 04:25 PM
T-B_MN's Avatar
T-B_MN
I don't have the ash tray (don't smoke anyway) i have the manual shift on the fly. I did drill a hole through that piece of plastic to run the wires from the back of the factory radio to my satellite radio. So no wires are showing and i think it looks really good. I can find some pictures if anyone cares.
It sounds to me like you are doing the same thing but with an iPod dock instead of a satellite radio.
Old Jul 19, 2007 | 09:15 PM
Well moldy taters. Got the adapter plate for my other stereo went to go put it in and now I have to put a different wiring harness plug thing on it. Witch realy urks my taters because i just put one on there not to along ago for my last truck. Do they make adapters from a Dodge to a Ford?
Old Jul 19, 2007 | 09:31 PM
FTE Trigger
What are you trying to install... or uninstall? OEM or aftermarket radio....?
Old Jul 20, 2007 | 03:20 PM
fordmtnman's Avatar
fordmtnman
On my XL with a manual trans, I have no ashtray or pull out cup holder. The Crutchfield instructions told me to start at the top, and yes the black piece around the stereo just pops off. The radio itself is screwed on with four 7mm fasteners.
Old Jul 20, 2007 | 03:49 PM
FORD7445's Avatar
FORD7445
i mounted my i-pod under the ashtray
Old Jul 20, 2007 | 05:01 PM
champ7718's Avatar
champ7718
Got any pix you could share?
