Digital Odometer
Old Jul 17, 2007 | 02:31 PM
johndeere214's Avatar
johndeere214
Digital Odometer
I have a 1999 F-150 and my digital odometer cuts out on me. I haven't been able to determine if it has anything to do with heat or cold or moisture. Has anybody else seen this issue. Any help would be great
Old Jul 21, 2007 | 01:33 PM
Franklin2's Avatar
Franklin2
I don't know the answer, except the old trick of taking it apart and putting it back together again to possibly disturb a bad connection. At least this will bring your post back to the top.
Old Jul 21, 2007 | 03:30 PM
projectSHO89's Avatar
projectSHO89
This is a pretty common problem.
Instructions are around here someplace (probably in the FAQs for the 97-03 section) to repair. It appears to be due to a common cold solder joint from when the display was made.
Steve
