low oil pressure
Old Jul 17, 2007 | 02:05 PM
gunit024's Avatar
gunit024
low oil pressure
I just bought a 1994 f150, I6, 5spd, 131,000 miles. I was told the engine has roughly 75,000 miles. The oil pressure seems to be very low, the gauge says its at the very bottom of the normal range. I've been told ford gauges are unreliable, could this be the problem? If not then how big a problem is this? This is the first ford I have owned, I got it because I read how great an engine the inline 6 was. In any case any help would be appreciated. Thanks.
Old Jul 17, 2007 | 02:44 PM
subford's Avatar
subford
If it is a stock gauge it is not a gauge so to speak.
It only indicates 0 or OK, it is using the oil light sender switch that only has an off & on.
Old Jul 17, 2007 | 03:54 PM
GRAVEYARDSHIFT's Avatar
GRAVEYARDSHIFT
Change the sending unit. Pat
Old Jul 17, 2007 | 04:03 PM
quicklook2's Avatar
quicklook2
check with mechanical gauge.
Old Jul 17, 2007 | 09:05 PM
870's Avatar
870
Go to Auto Zone get the gauge made by SUN (12.95) & you can install it in less than an hour. If you want to you can go buy pipe nipples & make a T & have both guages hooked up. I just done this to my 4.9L.
Oldmics
Jun 1, 2008 08:09 AM
CharlesNeff
Jul 17, 2007 06:51 AM
Munch
Apr 21, 2006 11:59 AM
sckent
Jul 20, 2004 11:24 PM
Paul Krause
1983 - 2012 Ranger & B-Series
Jan 11, 2000 10:17 AM
