Fuel Injection Not Functioning
Old Jul 17, 2007 | 08:45 AM
fleetboss's Avatar
fleetboss
Hi. I am trying to get the injectors in a 1989 Ford F250 with a 5.8 automatic to work. Someone previous to me was doing some cutting and splicing to the harness without really knowing what he was doing. I have it just about patched back together now. The fuel pump relay works, eec relay works, I have spark, the 2 injector banks have 12 volts. The problem is the computer is not grounding out the injectors. What sends the signal to the computer to fire the injectors? I won't rule out a bad computer, but this would be rare. Any thoughts would be appreciated. thanks.
Old Jul 17, 2007 | 08:56 AM
subford's Avatar
subford
Check the small black wire with a green or white stripe on it coming off the NEG post of the battery. This is the ground wire for the EEC Computer.
The PIP signal is what tells the Computer when to ground the Injector banks.
Old Jul 17, 2007 | 10:30 AM
Conanski's Avatar
Conanski
...And that signal comes from the TFI module which is either on the distibutor or fender mounted depending upon the year. The TFI in turn gets a pulse from the hall effect sensor which generates a pulse from the spinning vane inside the distributor itself.
Old Jul 17, 2007 | 10:46 AM
fleetboss's Avatar
fleetboss
Thanks for the replies. I see the PIP lead coming off the module that is mounted on the distributor. This lead has continuity going to the PIP pin on the computer plug. The computer has 3 grounds. One is the case ground (functional), two others are 'Batt' grounds according to the manual I have. Bolth of these are black with a green tracer. These 'Batt' grounds did not actually have continuity to ground, so for diagnostic purposes, I grounded bolth of them. The computer also has power coming in at 2 pins which I confirmed. If I were to try to verify that I have a PIP signal, how would I go about it? Is there something I am overlooking? If I am getting a spark (which I am), should I assume the hall effect is functional? Thanks
Old Jul 17, 2007 | 11:29 AM
subford's Avatar
subford
These two wires go to the NEG POST of the battery.
Should be three, Pin #1 at all times (Keep Alive Power), and pins #37 & 57 when the key is on.
Only way I know of is with a Scope.
I would say so but you could put a test light on the TACH side of the Ignition Coil and see if it has a steady flash while it is cranking.
Here is a diagram showing the power inputs of the EEC.
The wave forms from a scope.
And one of the Ignition system.
Old Jul 17, 2007 | 01:51 PM
fleetboss's Avatar
fleetboss
Bill, Thanks for the explanations, as well as the diagrams. I will be getting back over to that truck in a little while. I'll let you know what I find.
Tony
