Squeeking u-joint????????
Old Jul 16, 2007 | 08:30 PM
jlabrecquevt's Avatar
jlabrecquevt
'03 ranger 4x4 4.0L
When i take off from a dead stop there is a squeeking coming from the rear of the truck. It goes away when i hit about 10 mph.The squeeking noise is much worse if i am taking off from a dead stop up a hill. I am thinking its a u-joint on its way to the scrap metal pile. Has anyone had this problem. They are the zerk-less fitting type so no way to grease them. The drive shaft has no play in it, when i put it in neutral and spin it by hand. Should i replace them both (front a rear of the driveshaft? any advice would would be greatly appreciated. Thanks!
Old Jul 17, 2007 | 01:49 AM
RangerRuss's Avatar
RangerRuss
Check this first - common
http://rockledge.home.comcast.net/Ra..._Yoke_Lube.pdf
Old Jul 17, 2007 | 04:46 AM
pgw85706's Avatar
pgw85706
Originally Posted by jlabrecquevt
'03 ranger 4x4 4.0L
Is your truck manual or automatic and how many miles on it? Seems unlikely to have a bad u-jont on an '03.
Old Jul 17, 2007 | 08:16 PM
jlabrecquevt
Automatic 39,800 miles...seemed way premature to me to...But this morning the squeek went away.. I sprayed some PB blaster on it last night and now the squeek is gone..dont know what to do..any advice would be greatly appreciated..thanks
Old Jul 18, 2007 | 07:44 PM
jlabrecquevt
any other opinions? where i should start?..help please!
Old Jul 18, 2007 | 08:49 PM
RangerRuss's Avatar
RangerRuss
I have found that the grease from the factory on the driveshaft splines is somewhat short of minimal. It usually will cause a ever so slight hesitation when accelerating - like something is not tight in the transmission or driveline somewhere and it could make noise. It is an easy enough task then you can rest assured of adequate grease. Take the part numbers with you to the dealer to get the special lubricant. IMHO large tie wraps are sufficient to reseal the boot.
Russ
