S over the last few days my truck as developed a very loud scraping sound. It seems to be coming from the back of the truck and varies with speed. It only occurs under acceleration and neutral throttle, not while coasting.
My guess would be the rear brake, but I don't know squat about drum brakes and where/how to look for problems.
Look at the inside of the wheel for grease/oil. Wondering if rear axle bearing going bad.
Are any of the rear brakes geting very warm? Might have a brake hanging up if you do. Just do a feel of the rear drum for temp difference after a drive. CAUTION they can get very HOT.
Also try backing up and applying brakes. You might have a small stone between the drum and shoes.
