vent window
Old Jul 16, 2007 | 07:22 PM
Lee250's Avatar
Lee250
vent window
I have an 86 f250 and the little triangle vent windows are rotted out and I was wondering what year trucks will fit. Theres alot of 87 and newer but its hard to find 80-86s.
Old Jul 16, 2007 | 09:58 PM
ri_truck_guy's Avatar
ri_truck_guy
80 thru 91 should all be interchangable...Ford went to a wider vent window frame starting in 92.
Old Jul 18, 2007 | 10:13 AM
ken's 80's Avatar
ken's 80
If you are refering to the WINDOW FRAMES, not the door frame then check out LCM or BLUE OVAL parts. They have the whole setup in their catalougs. A little pricey but they're there.
Old Jul 18, 2007 | 10:57 PM
doctorolds's Avatar
doctorolds
Kens 80 is correct try LMC or Blue Oval.
Old Jul 19, 2007 | 09:32 PM
ken's 80's Avatar
ken's 80
OH YEAH...don't be cheap(like I was) and fail to replace the rubber around those windows while it's apart.
Unless that is, you don't mind the constant wind whistling when you're driving.
Kustomfiend
May 28, 2013 12:23 PM
Notmeofficer
Bronco II
Aug 25, 2012 09:57 PM
IcallHerBeast
Mar 29, 2012 10:00 AM
Tmill
Mar 15, 2011 06:42 AM
nakarsten
Mar 7, 2011 10:54 AM
