1978 - 1996 Big Bronco
Need some Help
Old Jul 16, 2007 | 01:28 PM
redchl's Avatar
redchl
Need some Help
I'm building up my 89 Bronco and need some help picking out the best parts for the axles. I will be using my Bronco on and off road and was wondering if I need to upgrade to heavy duty axle shafts and what diff I should go with?
Old Jul 18, 2007 | 12:00 AM
greystreak92's Avatar
greystreak92
How much modification are you looking to do? Gear swap? Suspension lift? Tires? Just depends on how much you want (or can afford) to do. All of these factors and more will dictate just what you end up with under the truck. Both the Dana44 and the 8.8 are pretty hefty axles with proven records to begin with. (Thats whats already under there). You would really have to get into some serious off-roading before they would limit your capabilities.
