M5OD = Manual 5 speed Overdrive as found in my '95 F150.
Spec Mercon is 7.5 cSt. I have run a 9.3 cSt fluid last 20,000 miles. Wondering how thick I can go without damaging the splash lubed bearing by running dry from too thick of ATF. Would like to try Redline MTL which is 10.6 cSt.
