another E4od problem, searched
Old Jul 16, 2007 | 11:41 AM
f100guy's Avatar
f100guy
hello, i am working on a 94 with an IDI turbo diesel. the trans has been rebuilt but it shifts hard and while it shifts, it slips. (it takes a few seconds to make the shift and you can feel it raise rpms a little. yesterday i put the new injectors and injector pump on it and test drove it. it felt like there was no OD intermittantly because i was cruising 55-65 at 3000 rpms maybe not even in 3rd. the OD light has started flashing now that i put the new injector pump on. could this be a problem with the adjustment on the sensor for the kickdown. it was shifting hard and slipping before the work but the light did not flash. what kind of scanner can be hooked up to this tranny to get codes. thanks all.
Old Jul 16, 2007 | 03:15 PM
ola1234's Avatar
ola1234
Fipl?
Have you been checking out the Fuel Injection Pump Lever?
Old Jul 16, 2007 | 04:17 PM
rattosh51's Avatar
rattosh51
the flashes are a code themselves....see what they are flashing and look them up or post them here.
Old Jul 17, 2007 | 08:32 AM
f100guy's Avatar
f100guy
i know it is a code, which scanner will work on it. i have not touched the pump, beside take it off and installing the rebuilt one. it was doing all this before
