Sponsored by: Auxito
Headlight Assembly Replacement
Old Jul 16, 2007 | 08:29 AM
Aztrainer's Avatar
Aztrainer
I am in the market to replace my headlights, but I would like to get some recommendations of what you have used. I also would like to know how easy it was to change with the OEM. I am looking at replacing the headlight only, but am open to any other style you use. Thanks for your help on this.
Old Jul 16, 2007 | 08:42 AM
galaxie641's Avatar
galaxie641
It is incredibly easy, simply pull the tabs up, pull the assembly straight out and unplug it. I personally use the depo style Lightning knockoffs, you kind find them quite a bit cheaper than the OEM Lightning heads and they look and work just as good. I also use the L corners.
Old Jul 18, 2007 | 05:32 PM
Smaug's Avatar
Smaug
Check my gallery for Depo L style w/ projector. I will also update my gallery later to include my new ones. They are APC black w/ projector.
