Sponsored by: Auxito
Wheel Bearing Replacement
Old Jul 15, 2007 | 10:54 PM
79pos's Avatar
79pos
Finally diagnosed the clunking in the rearend and its the passenger side wheel bearing. The only problem with that is I have no idea how to do the bearing or seals. So I was wondering if somebody had a link to step by step instructions on how to do it or a link to somewhere.
Old Jul 16, 2007 | 12:04 AM
Matts72's Avatar
Matts72
What truck do you have? 8.8s are the easiest to do axle bearings on. Just pop the cover, the c-clip and pull the axle.
Old Jul 16, 2007 | 06:00 AM
79pos's Avatar
79pos
Its a 99 f-159 is a 4x4 off-road with 3.73 gears I think its the 9.75 but I'm not sure. It also has the limited slip.
Old Jul 16, 2007 | 04:20 PM
Matts72's Avatar
Matts72
I would recommend picking up a Chiltons manual for the truck, it'll give you very detailed instructions and torque specs, which are critical in the rear diff. I'm not familiar with the 9.75 rear. You might do a quick search in the rear diff forum, further down the main index.
