Slow cranking upon starting
Old Jul 15, 2007 | 10:20 PM
Buicksx2's Avatar
Buicksx2
Hi All,
I noticed a problem lately with my 99 PSD, it seems that when I go to start the truck it is real slow in cranking over almost like batteries are going or dead but it eventually turns over.
I cleaned up battery terminals and it's still the same. I ran truck to my buddy who is a mechanic and both batteries are over their cranknig amps and alternator and everything is charging fine.
I bought the truck with 200K on it and it now has 202K on it and since I bought it on Ebauy I don't really have a sense of the history other than what I got from the dealer.
If the truck needed glowplugs would that cause a slow cranking situation?
Thanks in advance fro any and all help.
Old Jul 15, 2007 | 10:24 PM
Uzumati's Avatar
Uzumati
Check the voltage at the battery during cranking. It must remain above 10.5VDC.
Could also be the starter binding up is the voltage checks out.
Old Jul 15, 2007 | 10:31 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Also, check your connections at the starter solenoid, and the starter itself. While doing that, have a look at the connection at the GPR, but only because you're checking things anyway. Might even try jumping the solenoid to see if it cranks better. May just need a new solenoid.
Old Jul 15, 2007 | 10:46 PM
Buicksx2's Avatar
Buicksx2
Thanks guy for the tips..........I am due to take truck to another buddy who is a diesel mechanic soon and will take this with me.
This is a great board, as a newbie PSD owner I have learned alot from you guys. I appreciate it.
GreenRino
Jul 25, 2014 06:25 AM
rjack
Jun 3, 2013 07:15 AM
kt19
Jan 4, 2012 10:15 PM
katiesdad7
Dec 10, 2010 08:30 PM
DANDYoDAN
Apr 4, 2005 11:53 AM
