Electric Fuel Pump Question
Old Jul 15, 2007 | 09:33 PM
77F-150's Avatar
77F-150
Question Electric Fuel Pump Question
I recently fixed my truck but i was wondering, my truck has an electric fuel pump it looks like a fuel filter from those 95 and up chevies (best way to describe it) but here's my problem when my gas gauge reads thats theres just enough gas in my truck where the needle is slightly up from the (E) and i start going down the road but my truck stalls but the gauge needle is still slightly away from (E) telling me that there's still enough gas but my truck still stalls. my gas tank is in the back of me or my seat i should say, i know there's still enough gas in there cause i pulled out the sending unit and found that there was still barely enough gas but you guys that have those gas tanks in behind the back seat is that normal for that to happen? or is my electric fuel pump not sucking up enough to get the gas at the bottom of the tank?
Old Jul 16, 2007 | 09:42 AM
trinogt's Avatar
trinogt
Where is your electric fuel pump mounted?
It needs to be below your fuel tank so it pushes fuel, not pulls it. If it tries to pull the fuel, it will soon burn out from lack of cool fuel flowing through it.
The burnout is sometimes gradual, where stalling will occur now and then; Or, sudden death can occur with no chance of a restart.
Old Jul 16, 2007 | 12:19 PM
77F-150's Avatar
77F-150
Here the pic of the electric fuel pump
[img]gallery/150Ford/751970.jpg[/img]
Old Jul 16, 2007 | 12:21 PM
77F-150's Avatar
77F-150
Here's the pic of my electric fuel pump,
Old Jul 16, 2007 | 06:54 PM
rusty7983's Avatar
rusty7983
my incab tank is a pain in the rear. (77 f350 ) i cannot let my tank go 100 miles without sputtering and "running" out of gas. i have assumed that the feed line has a pin hole in it. one day it was 4.? gallons down, a couple days it was just over 5 gallons down. now i drive local till my newer tank arrives.
Old Jul 16, 2007 | 07:22 PM
77F-150's Avatar
77F-150
Those type of fuel pumps, do they have enough sucking pressure to reach the gas tank in the back? for some odd reason my 300-6 does not have no mechanical fuel pump on the engine
Old Jul 16, 2007 | 11:59 PM
fasthauler's Avatar
fasthauler
The pickup tube in most of these tanks don't go all of the way to the bottom. They are just off of the bottom to keep from picking up crud off of the tank bottom. This does leave about a 1/4 inch of gas on the bottom. My 68 was like this, I don't know how many more were. (I didn't know 77's had an in cab gas tank)
My personal opinion would be to get that tank out of the cab and under the vehicle. I spent 10 years in the fire department and I saw first hand what can happen if you get in an accident and get trapped in the cab. You might at least have a chance if the tank is under the vehicle.
Old Jul 17, 2007 | 12:06 AM
77F-150's Avatar
77F-150
Yeah i know my brother in law said he wouldnt fill safe just sitting there with all that gas behind the back seat lol, i was wondering if that small electrical fuel pump would be able to suck the gas through the back tank or would i have to relocate it towards the rear of the tank?
Old Jul 17, 2007 | 12:23 AM
fasthauler's Avatar
fasthauler
It wouldn't be that hard to relocate, and yes it should be near the tank so that it pushes instead of pulls. This makes the pump run cooler and last longer. Also I would suggest that if the mechanical pump has been removed and this is your only source of fuel to the engine that you carry a spare. I have been running electric pumps for years and believe me they do go out. It gets difficult sometimes to find the exact pump to replace the bad one and it is no fun trying to adapt another type of pump when you are broke down along side of the road.
Old Jul 17, 2007 | 12:41 AM
Torque1st's Avatar
Torque1st
Posting Legend
Actually the pump does not "suck" anything. Atmospheric pressure in the tank forces fuel in the tank thru the line into a void in the pump mechanism. If the fuel line inlet filter is not totally covered by fuel air will rush in to fill the pump void causing the pump to deliver air instead of fuel.
A fuel pump should be located as close to the tank as possible.
Remember- It is just as easy to keep the top half of the tank full as it is the bottom half!!! Always refill your tank before it reaches 1/4 full.
Old Jul 17, 2007 | 12:43 AM
77F-150's Avatar
77F-150
Believe me ive been on the side of road more times then ive been driving on it! I do have a 302 that im swapping out pretty soon so hopefully all goes well.
Old Jul 17, 2007 | 10:38 AM
fasthauler's Avatar
fasthauler
Gee, did we just get a lesson in advanced physics or what!
And all this time when I put my finger over the inlet of an electric pump and it stuck, I thought it was suction. It turns out all this time that it was atmospheric pressure
Old Jul 17, 2007 | 04:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Correct, that is why you can't have 100 PSI of suction above sea level here on Earth. Vacuum or "suction" readings are differential pressures. It is important to realize that "suction" is actually atmospheric pressure differentials and it is ambient pressure that is driving the inlet side of pumps when trying to diagnose problems. This is particularly important when people plug the gas tank vent line when foolishly removing the charcoal cannister in the vapor recovery system while they have a tight fitting gas cap. -oooops!
-Now somewhere deep in Jupiter or in the depths of the oceans here on Earth you can get some rather large vacuum readings...
Old Jul 21, 2007 | 03:14 AM
77F-150's Avatar
77F-150
I have another question, someone told me that the pick up tube inside the bank tank behind the seat is adjustable or you can adjust it...is that true?
Old Jul 21, 2007 | 04:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One reason why the dash gauges are inaccurate is the gas tank sending unit floats. The floats are made from two pieces of copper soldered together. Over time, the solder breaks down, allowing gas to seep into the float. The float then settles to the bottom of the tank.
The floats are still available from Ford and were used on every Ford gas tank sender, car & truck from 1957 thru 1979.
C0AZ-9202-B .. Gas Tank Sender Float
C1TF-9276-A .. Gas Tank Sender Gasket - Use with bolt on sending units.
C0AF-9276-A .. Gas Tank Sender Gasket - "O" Ring type - use with senders that are held on by a twist off ring.
Note: The under bed gas tanks have a plastic mesh filter screen that slides over the end of the pickup tube. Most have never been changed, so many are partially/totally clogged up. It's still available from Ford.
D1AZ-9A011-A .. Plastic Mesh Filter Screen
Note: The in-cab gas tank sending unit assembly is still available from Ford. The same sender fits every in-cab tank from 1961 thru 1977.
D7TZ-9275-G .. Gas Tank Sender = In-Cab Gas Tank: 1961/77
