tranny swap
Old Jul 15, 2007 | 05:43 PM
forgottenben's Avatar
forgottenben
tranny swap
I have two 1988 f150s, one a long bed 3 speed auto 4 wheel drive with a lot of rust, and a short bed 2 wheel drive 5 speed manual. I a wanting to convert take the 4 wheel drive stuff off the long bed and put it on the short bed. I am also wanting to keep the manual transmission on the short bed. Is the 5 speed compatible with the 4 wheel drive, will I need to buy an adapter or a different tailhousing?
Old Jul 15, 2007 | 08:18 PM
lostin90s's Avatar
lostin90s
No . The 2x4 has different housing.
Old Jul 15, 2007 | 08:28 PM
forgottenben
well that sucks. no way at all to convert it?
Old Jul 15, 2007 | 10:42 PM
archangel's Avatar
archangel
The stick shift trans needs a different output shaft and the proper tailhousing/adapter (assuming there was a factory or aftermarket option to put the two together) and adjusting the rear driveshaft.
cutting a hole in the floor for the transfer case shifter.
Also swaping the front axle and all the related parts.
