tranny swap
Old Jul 15, 2007 | 05:41 PM
forgottenben's Avatar
forgottenben
tranny swap
I have two 1988 f150s, one a long bed 3 speed auto 4 wheel drive with a lot of rust, and a short bed 2 wheel drive 5 speed manual. I a wanting to convert take the 4 wheel drive stuff off the long bed and put it on the short bed. I am also wanting to keep the manual transmission on the short bed. Is the 5 speed compatible with the 4 wheel drive, will I need to buy an adapter or a different tailhousing?
Old Aug 3, 2007 | 03:05 PM
amish77's Avatar
amish77
Tail housing yes, adapter I don't think so. There was only one Transfer case used in '88 to my knowledge. The drive shafts will also have to be sourced, as well as well as the front drive axle off the 4wd. This will be quite a job.
Old Aug 3, 2007 | 04:46 PM
andym's Avatar
andym
You need to either get a 4wd manual transmission or use your automatic. You can't convert a manual from 2wd to 4wd.
