Tranmission Problems
Old Jul 15, 2007 | 04:06 PM
armyboy's Avatar
armyboy
Question Tranmission Problems
Ok finnaly went and got my 89 F250.. it has a 351W in it and i belive a C6 tranny..... now my problem. It wont move. 4 hi 4 lo 2 wd it doenst have an affect at all on it.. but when you take the tranny from Park and put it into gear and try to put it back into park it starts grinding like hell... is this a bad transmission? oh yeah i had it in reverse and was playing with the t-case shifter and it died on me.. PLZ HELP thanks all
Old Jul 16, 2007 | 05:29 PM
Holmesuser01's Avatar
Holmesuser01
I think your transfer case is messed up. When you took the tranny out of park, it started spinning. When you shoved it in park, well, you told us.
Good luck!
Old Jul 16, 2007 | 05:37 PM
armyboy's Avatar
armyboy
well i had the front hubs locked in and went from 2wd to 4 hi and low and nothing happend other than the grinding noise when you put it into park.. i dont know much about trannys or t-cases so i have no clue
Old Jul 17, 2007 | 07:23 PM
Holmesuser01
I bet that your tranny output shaft is spinning when you take it out of park. Since there is nothing working on the transfer case, it just sits there spinning, until you put it in park. The grinding you hear is probably the park pawl. Dont do that too much. You might make things worse. Sounds like someone here needs to jump in that knows more about transfer cases than I do.
Old Jul 17, 2007 | 07:26 PM
armyboy's Avatar
armyboy
Unhappy
well i dont know squat about trannys and t-cases (only my second 4x4 first was a jeep).. is this a fairly easy fix if it is the tailshaft.. or is it a complete rebuild?? thanks to all that answered
Old Jul 20, 2007 | 03:21 PM
bocephus_3349's Avatar
bocephus_3349
I'm no specailist but I say drop the T/C and see if everything is in working order. spin the input and see if the rear out moves is prob first thing i would try. Shouldnt take to long to drop it. they come out pretty easy without much cussing.
hotrod351
17
Sep 10, 2014 08:53 PM
trappnman
1983 - 2012 Ranger & B-Series
16
Jun 21, 2013 03:24 PM
tumbleweed2
Aug 18, 2009 04:43 PM
goalie
Nov 18, 2002 11:55 AM
