Sponsored by: Real Truck
Leveling Kit
Old Jul 15, 2007 | 03:39 PM
Ramblinrich's Avatar
Ramblinrich
Question Leveling Kit
Does anyone know where to get front coil spacers for a 94 diesal 2wd?
Thanks
Ramblinrich
Old Jul 21, 2007 | 06:37 PM
ReAX's Avatar
ReAX
Good luck with that. Energy Suspension makes some universal poly spacers, you might also try ready lift.
Old Jul 22, 2007 | 11:38 PM
twjull's Avatar
twjull
Do not mess with spacers!! Get new coils that are taller if availilible for what you are trying to accomplish!!
Old Jul 23, 2007 | 06:40 PM
Ramblinrich
Terry,
Why do you say not to use spacers for only a 2" lift?
Ramblinrich
Old Jul 23, 2007 | 07:50 PM
twjull's Avatar
twjull
Ramblinrich,
I guess i started it so here goes the problem I had.
I restored a 1984 F-150 2 wd. In effort to make it look cool I put 20" rims and tires on it, big mistake! Tires rubbed on the wheel wells when I drove over any kind of bump and tight radius turns it rubbed on the sides of the wheels.
I think you are having the same problem I did in finding spacers to fit your truck or for the coils. Most spacers and blocks are made for 4wd models and not 2wd. None were made for mine. I went to a coil shop and they found a spring that would lift the front the 2" and was within the specs by Ford for the truck. Becareful not to put any coil in unless you check it against Ford's specs.
Worked great tires don't rub, now the truck rides as rough as Mechanical Bull! In order to get 'taller' spring they had to put a stiffer / stouter coil in. So watch out for that little surprise.
By the time they were done with a new alignment it was $600.00 for a 2" lift.
Hope this gave you some insight!
Old Jul 23, 2007 | 08:06 PM
Ramblinrich
Thanks for the insight.
Ramblinrich
