Sponsored by: Real Truck
lie-o-meter
Old Jul 15, 2007 | 12:04 AM
yamaguy's Avatar
yamaguy
lie-o-meter
I know that most people say that the overhead console (99'-04')is very inaccurate, but is that true for everybody? Please tell how it is with tuner and stock.thanks for the input.
Old Jul 15, 2007 | 04:43 AM
MobeyDick's Avatar
MobeyDick
Stock it was off by 1.5 MPG It showed High. With the Hypertech Programmer it shows about 4.5 better then actual. with the DP Tuner it shows about 3 MPG better then actual. Actual right now with the DP Tuner it's 13 MPG.
Old Jul 15, 2007 | 06:49 AM
msgtg's Avatar
msgtg
No tuner, but I've checked it by doin the math and mine is right on.
Old Jul 15, 2007 | 07:58 AM
dayooper's Avatar
dayooper
mines usually .8 to 1.4 off not to bad
Old Jul 15, 2007 | 04:01 PM
BobbyDiesel71's Avatar
BobbyDiesel71
what does yours read normally?
just curious
I will post mine as soon as I can. I think it is off, not sore how much, though
Old Jul 15, 2007 | 05:08 PM
gjmack3's Avatar
gjmack3
I've checked my fuel mileage with every tank since I bought the truck, and mine has been right on. It may be .1 or .2 off sometimes, nothing to write home about.
Old Jul 15, 2007 | 08:02 PM
ryaneverk2's Avatar
ryaneverk2
They all vary fantastically. Some will be spot on, others will be off by 1 or 2, many (mainly with tuners or something similar) will be off by a few or more mpg. Mine tends to read 3-5 mpg over what I hand calculate.
Old Jul 15, 2007 | 11:05 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Mine seems to be dead on with AVG mpg, however, my range-o-meter is a teller of tall tales. That bugger will tell me I lost 30 miles off my range when i have only gone 3 or 4 on teh e-way. One thing is for certain, when it says I have a 0 mile range it is telling the truth!
Old Jul 15, 2007 | 11:46 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Today I held both buttons till is said cal and then went down a hill and said I was getting 50 yah right
Nick
Old Jul 16, 2007 | 12:03 AM
BobbyDiesel71
I don't understand what you did?
I have never done that trick
can you explain it further?
bob
Old Jul 16, 2007 | 06:01 AM
msgtg's Avatar
msgtg
Nick, I'm not sure what you did but I do know there is a way to change the read-outs from standard to metric. It sounds like that's what you've done.
Joe
Old Jul 16, 2007 | 11:50 AM
5.4L to Freedom
Nick
If you reset the computer, at a high speed and do not touch the throttle, your computer calculates fuel consumption of idle vs. your current speed. 50mpg is achievable if you are coasting down a hill without touching the gas, but AS soon as you touch the throttle it should "plummit back to reality"
If you are intrigued by this concept, mash the gas to the floor and reset it at wide open. You'll be lucky if it youi are getting 3, but as soon as you let off it'll shoot up to about 9
Old Jul 16, 2007 | 12:14 PM
harald's Avatar
harald
Mine is consistently high by about 0.5 mpg. This may not seem like much, but at 10 mpg around town with my 4.30 geared, 7500lb, V10 truck that comes out to a 5% error. And my miles to empty is inaccurate also; I've gone 30 to 50 miles after is said 0 miles to emtpy and never ran out of gas. This is with stock truck.
Old Jul 16, 2007 | 12:46 PM
grndprxguy's Avatar
grndprxguy
Not sure if this is true for the fords, but on my lincoln the average MPG was calculated for the last 500 miles unless you reset the computer manually. This may explain the variance that some of you see.
Old Jul 16, 2007 | 12:59 PM
5.4L to Freedom
AS SOON AS i reset my computer it sets everything to 0.00
