Sponsored by: Auxito
Airbag code 1921
Old Jul 14, 2007 | 11:54 PM
Putt's Avatar
Putt
Airbag code 1921
1999 F150 Supercab,4x4, 5.4L, 115000 miles. I have an intermittent B1921 code:RCM detects resistance over 100 ohms between ground connections at the housing and reference ground at RCM terminal 21. I have some diagnostic info, but when I accessed the RCM, it is not bolted in??? It is just setting on the bracket behind the lower, center heat vents. Is this correct?? or should it be bolted in place?
TIA
Old Jul 15, 2007 | 06:11 AM
ncranchero's Avatar
ncranchero
It should be bolted in. That may or may not affect your intermittent ground fault but get it bolted back in for sure. There should be an mounting orientation arrow on the top.
Old Jul 15, 2007 | 08:03 AM
Putt's Avatar
Putt
Yes, there is an arrow to show front. I will find/purchase appropriate bolts and fasten it in place.
Thanks Steve
muMMie
Oct 27, 2014 12:30 PM
nicks1k
Sep 4, 2014 04:30 PM
truckh
Escape & Escape Hybrid
Mar 26, 2014 11:01 AM
daveya48187
Jan 9, 2012 09:05 AM
exavowner
Jul 25, 2008 02:20 PM
