Problem With Rear Axle/Differential...
Old Jul 30, 2007 | 11:51 AM
fasthauler's Avatar
fasthauler
I get a little carried away on my maintenance. I change the rear fluids out every 50k and the tranny every 25k. I check the tranny and rear end levels at least once a month. Most guys say this is overkill but I get 300k plus on every vehicle I have ever owned without any major breakdowns. It is a lot easier to maintain them than to fix them alongside the road in an unfamiliar area.
Old Aug 2, 2007 | 02:54 AM
SeannyBoy84's Avatar
SeannyBoy84
alright well i've driven over 50 miles and everything seemed to be great, until today. i noticed recently that when i turn left, i can hear a soft rubbing metal sound. sort of like what the brake pads would sound like rubbing on the rotor. it only happens when i turn the wheel to the left, even so slightly when i'm changing to the next lane over. i'm gonna take a closer look tomorrow, but what would cause something like this to happen when i'm turning?
Old Aug 2, 2007 | 11:51 AM
fasthauler's Avatar
fasthauler
Usually a noise while turning is a good indication of a bad wheel bearing, but in your case I think I would start by sliding underneath and look for shiny spots. Make sure that the differential is not shifting and causing something to rub. It also could be a loose wheel bearing. You might check it and see if it is tightened to specs.
corksil
31
Dec 12, 2016 11:07 AM
timbersteel
Sep 30, 2016 04:31 PM
Betsy1985
Aug 9, 2016 06:51 PM
Stlrrig
Escape & Escape Hybrid
24
Aug 8, 2016 12:49 PM
acf6
May 9, 2016 12:42 PM
